![]() Drives: Yaris Join Date: Jan 2011
Yes it does and so does the fuel Gauge but other things like left and right turn work and temperature airbag light all work.
thanks |
#2 | |
All three of those should have 12 Volts on them. if one does not, when the speedometer is not working, then that particular feed is the issue (for example it could be that the ACC relay contacts are not closing properly if the grey wire does not have 12 Volts on it). 1999 - cluster C13.jpg 1999 - cluster C15.jpg
