Old 02-09-2013, 04:53 AM   #1
petefozzy
Drives: Yaris
Hi again checked all the connections all seem ok so now at a loss as what to do next does this point to a faulty speedometer or to the speedo sensor because all of a sudden the display will come back on and all seems well for awhile before it goes off again.
Thanks Pete
petefozzy is offline   Reply With Quote
Old 02-09-2013, 07:15 AM   #2
Thanks Pete
If the speedo sensor was bad you would just see 0 MPH, as opposed to a blank display, so it really points to an intermittent power feed to the speedo or an intermittent fault on the circuit board. Do you have anyone that you can temporarily swap speedometers with to see if it follows the car or the speedo?
Old 02-09-2013, 07:24 AM   #3
petefozzy
Drives: Yaris
Thanks I will see if I can get hold of one to try are they all the same even diffrent years my local breakers yard has one and he assures me that it works so may have to purchase that as dont think it is speedo sensor and all power to speedometer seems to be ok.
once again thanks for your help.
