![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
Did you check and see if your Cabin Air Filter in the blower housing is clogged up or not there?
If it is not there {seems many Yaris's shipped with out one in the housing} did you suck some foreign material into the blower housing and it has restricted air flow? http://www.yarisworld.com/forums/sho...ight=cabin+air |
#2 | |
![]() Drives: 08 Yaris Join Date: Jan 2012
The cabin air filter was changed recently, so I don't think that should a problem. |
#3 | |
#4 | |
Thanks for the replies by the way. |
If you pull the corner of the carpet away from the big white air box, next to the gas pedal, you will see the AC ECU. If it has one connector, it is not equipped with the PTC heater, and if it has two it is.
| Coolant Smell after sitting in hot sun? | Snappy | General Yaris / Vitz Discussion | 3 | 05-31-2009 12:18 AM |
