If you pull the corner of the carpet away from the big white air box, next to the gas pedal, you will see the AC ECU. If it has one connector, it is not equipped with the PTC heater, and if it has two it is.
| Coolant Smell after sitting in hot sun? | Snappy | General Yaris / Vitz Discussion | 3 | 05-31-2009 12:18 AM |
