![]() ![]() ![]() Drives: Toyota Belta Join Date: May 2011
I've had my Belta for 2 yrs and never had to replace the battery. The battery it carries is the CR2016.
Does your belta have "smart entry" with no key and push button start, or does it have keyless entry? Keyless entry remotes only use the battery when you push the lock or unlock buttons, whereas the smart entry has an active RFID transponder, which draws from the battery even when no buttons are pressed.
| Transponder key programming | teddy | DIY / Maintenance / Service | 6 | 04-28-2015 07:32 PM |
| 2007 Yaris Keyless entry key | kev084 | DIY / Maintenance / Service | 1 | 07-03-2012 01:24 PM |
| 2007 Yaris Keyless entry key | kev084 | DIY / Maintenance / Service | 0 | 07-03-2012 08:23 AM |
| I lost my master keyless entry key, need suggestions.... | Frankd1 | DIY / Maintenance / Service | 19 | 12-02-2010 12:13 AM |
