Old 02-11-2013, 08:43 PM   #1
r55nls2002
Drives: 2000 Echo Coup... Red
Let me get this straight... The violet wire directly connects the sender to the cluster. OK, I honestly don't think it is the sender because the new unit is doing the same thing the old unit was doing. I think it is the wiring itself. All the wires coming from the sender look a bit sketchy. Hopefully it is the sender because I really don't want to run new wires thought out the car.
Thanks -
r55nls2002 is offline   Reply With Quote
Old 02-11-2013, 08:54 PM   #2
Thanks -
That is correct. There is one junction connector between the sender and the dash, but, if the wire was damaged you would more likely see the tank as empty, rather than half full.
