Let me share my experiences. First you should understand what spring rating means.
For instance, 4k Rating means for each 4 kilogram the spring will compress 1 millimeter, or ~224lb/inch. From there you can start seeing what rating you will need at what spring free length to get your desired drop. Im on 8K with 7" free length before compression. With the weight in the rear, the spring compresses just about an inch. With 4K it would drop 2 inches. I can tell you that i am 1 collar ring away from being as low as i can with that particular spring. I would recommend getting a shorter spring when you go up in stiffness. Measuring from bottom of my 14' rim to top of fender my rears are at 20 1/16". Front at 19 7/8"
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 Last edited by ezhacker1; 02-19-2013 at 01:21 AM. |
| Lowering spring question? | ijose 845 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 03-18-2012 01:59 AM |
| reverse gear..quick question.. | Yaris2910 | DIY / Maintenance / Service | 10 | 01-11-2011 05:14 AM |
| Quick Oil Question | nickhjort | Performance Modifications | 5 | 04-27-2010 08:51 AM |
| Quick question.. | harveyjai | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 03-21-2009 05:38 PM |
| Lowering, shocks question... | ToTo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 05-23-2007 11:55 AM |
