2ZR swap. DO IT! Ask how!
My goal with this design is to use a 90° silicone reducing elbow (2.5" -> 2.25" or 2.0") or something of that sort to connect to the Blitz. I think that the xB intake tube would be ideal, since it's already cut and round, but convincing someone to swap could be difficult.
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
An adaptive slip on coupling is a good idea, Cranky.
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
I'd definitely 1zz my Blitz if there was a way to make it bolt on.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
play every day
It just depends on how much higher it would be...
OK, here's a little better info: I measured the intake at 2.06-2.07", meaning 52-52.5mm OD. Looks like the bellmouth would need another spacer or have to be flared.
The good news is that a 2.5" -> 2" silicone coupler would allow my bracket to fit, but it would need another mounting point for the radiator hose. I'm still thinking that the xB intake tube would be the best way to make it happen since it is round all the way at the top instead of all squashed like ours. |
#7 | |
play every day
[quote=CrankyOldMan;702651]OK, here's a little better info: I measured the intake at 2.06-2.07", meaning 52-52.5mm OD. Looks like the bellmouth would need another spacer or have to be flared.
Wow... that's really small. ![]() Quote:
By the way what is an "xB intake tube"? Can you post a pic of one? |
Did you measure the diameter on an XB kit or a Yaris kit? I know the Yaris has a single piece pipe thing that comes off the top of the supercharger where the XB kit has that split one. I wonder if they might be different diameters?
I measured mine from my Yaris kit. As far as I know, the TB bore is the same, so the blitz runner bore should be the same. I can't tell from the images if the lower half of the runner looks bigger or not, so the OD is unknown unless you can get an xB owner to measure theirs.
play every day
With in inside diameter of 46mm and an outside diameter of ~52mm the Blitz intake must be an extremely thin casting to have walls that are only 3mm thick. That's tubing thickness. I'm wondering how they were able to pour aluminium into such a thin casting without leaving porous pockets.
It's a very strange casting, indeed. You can see lots of seams inside from the different sections of the wax master that were never smoothed out, like bad concrete foundations.
While waiting for my engine to cool off enough to change the oil yesterday, I installed my injen CAI. Some interesting things to note:
* The stock throttle body is TINY compared to the 1ZZ. * The injen intake isn't a suitable donor for a 1ZZ due to the diameter of the mating end and the limited space to clamp a silicone coupler near the MAF mount. * Finding an inexpensive aftermarket intake to scavenge a MAF section from is difficult, now that the Simota is not readily available. * Finding an off-the-shelf 2.25" MAF section is pretty much not going to happen. * Putting an intake on a supercharged engine makes for some really silly noises. * There is a LOT of room to get creative in there, provided you can do all the silliness where the OEM intake was--not much clearance at the top of the S/C. Correction: this may be a suitable alternative source for a MAF section, assuming you can deal with a 3" body: http://www.spectreperformance.com/in...apter-kit.html Last edited by CrankyOldMan; 06-23-2013 at 10:59 AM. |
#14 | |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
I tried the Spectre 3" MAF - immediately threw a CEL - MAF out of range. Unless you can modify this setting with the ECM - 3" is just too big for the 1.5. |
#15 | |
play every day
It's well worth it, if only just to get a MAF section. |
#16 |
#17 |
play every day
And save the other pieces...
With careful cutting and straight silicone couplings you could create any custom shape intake you wanted. edit: Just checked the seller's feedback and couldn't find any negatives for that intake. And they sell at least 2 of them a month. Last edited by tooter; 06-25-2013 at 11:53 PM. |
#18 | ||
| BLITZ supercharger kits IN STOCK | cali yaris | Micro Image | 34 | 06-02-2012 11:31 AM |
| FS: blitz supercharger kit + camcon | vten | Items for Sale by private party | 20 | 02-22-2012 10:12 AM |
| Blitz supercharger and everything else. 56K beware | camelll | Items for Sale by private party | 23 | 05-06-2011 10:32 AM |
| gap for spark plugs for the blitz supercharger? | whooppee777 | Forced Induction Forum | 2 | 03-12-2011 02:09 PM |
