![]() Drives: '08 Yaris 3 door Join Date: Feb 2013
Cupping on interior shoulders of rear tires
Hi everyone, my GF has been putting a lot of highway miles on her '07 yaris 3 door recently, and I noticed a lot of road noise from the rear of the car. Got down and looked today and the tires are beginning to cup quite a bit on both rear's on the inside walls. I did a quick check on the fronts, they looked fine but I should look again. What could be the problem here? The car has about 120Kmi on it.
Mr. Clean
Lack of tire rotation.
![]() ![]() ![]() Drives: 08Yaris2D, 88LandCruiser. Join Date: Jan 2013
Shot shocks., bad bearings(less likely).
I pushed on the car and it didn't keep bouncing, but I suppose with 120K the shocks are about due. It doesn't sound to me like the bearings are going on the car, kind of noisy but I relate that more to the cupping of the tires.
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
If it is just the inside edges that are wearing, it's probably toe wear. Blown rear shocks will make for cupping across the entire tread, worse in the middle.
What tire are they? Some tires are very prone to cupping/noise just by design. |
#7 | |
What would cause this? Wheel bearing? something else? |
Mr. Clean
Rotation as in removing the wheels and tires and rotating them to a different position on the vehicle. This is done to prevent uneven tread wear and prolong the life of the tires.
Ah, understood. She is definately overdue for a rotation, but (and maybe I'm wrong) I would assume cupping would point to a suspension issue, I was under the impression that rotating just allowed all four tires to wear evenly in relation to eachother.
I just looked into the rotation issue some more. Definately thinking thats the problem, its been at least 1.5 years since she rotated the tires. I've been a amateur-ly working on cars for the last 5-6 years and never heard about that one. I just assumed rotating allowed all four tires to wear evenly in relation to each other. Thanks for the info.
#11 | |
Only Happy When it Rains
Colin Chapman disciple |
The rear suspension of the Yaris should make for flat tire wear. You should not see any cupping from the rear at all. The idea is to take the tires from the front of the car (where they get worked hard doing steering and camber changes) and put them on the rear so they can become smooth again. Chances are you have some toe-in on the rear axle (from pothole or curb bump most likely). It is possible that it is from lack of rotation, but it is unlikely IMO. I would suggest getting your alignment checked. Do a google image search for "toe wear" and compare to what you have.
Cheers. |
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
The cause of cupping can be a tough one to determine, but i'd go with worn shocks and negative camber, or negative camber and toe in.
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 09:44 AM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
