![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
the stock shocks are the softest ones. tokico shocks are close to OEM ride as their OEM manufacturers of Hondas' shocks, probably even Toyotas'. KYB may not be the stiffest (I wouldnt know) but they are definitely stiff, let alone the gas type.
It's not the shocks' stiffness that caused them to go, it's the springs you have that destroyed your shocks. if they are too stiff, you will heat the fluid inside the shocks faster causing the shocks to burst in no time. In a nutshell, change your springs to Tanabes (probably, as IMO they are one of the OEM ride quality aftermarkets) otherwise you will have to go with stiffer shocks, contrary to what you were expecting to get from this topic--again, it's due to the stiff springs. |
#2 | |
This is sooo wrong on so many points.
| Tags |
| shocks replacement |
| Front strut replacement/ suggestions | jstantherprsn | DIY / Maintenance / Service | 4 | 04-28-2011 03:39 AM |
| Tein S-tech Springs with Stock shocks combination. | daddz07 | California | 11 | 08-21-2010 01:49 PM |
| Tein S-tech over Stock shocks | daddz07 | General Yaris / Vitz Discussion | 0 | 08-10-2010 10:48 AM |
| Tein S-tech Springs with Stock shocks combination. | daddz07 | Performance Modifications | 1 | 08-09-2010 03:45 PM |
| front shocks independent from rear shocks? | ammophobia | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 02-04-2010 11:34 PM |
