Can I use 14 inch wheels in H stock AutoX?
Well, a set of used Hankook Ventus Z214 C71 just rolled into my garage 205/55X14. Wondering if I can use these in H Stock AutoX. My 2009 hatch has TRD rear sway bar and TRD exhaust, that's it. If so, what width and offset is permissible? Thanks.
only the stock width is allowed.
offset has to be within + or - of 1/4" from stock |
![]() ![]() Drives: 2008 HB Join Date: Dec 2012
here is the wheel rule on page 75 of the 2013 Solo rule book
13.4 WHEELS Any type wheel may be used provided it complies with the following: it is the same width and diameter as standard and as installed (including wheel spacers if applicable) it does not have an offset more than ±¼” (±6.35mm) from a standard wheel for the car. The resultant change in track dimensions is allowed. Tire pressure monitoring sensors may be removed. Wheel spacers are permitted, provided the resultant combination complies with the offset requirements of this section. Wheel studs, lug nuts, valve stems (including pressure-relief types), and/or bolt length may be changed. Vehicles equipped with rims having metric specifications may use alternate rims as determined by using the following procedure: Diameter: converting the metric measurement to inches and using the nearest smaller inch diameter rim. Width: converting the metric measurement to inches and using the nearest smaller ½” (12.7mm) width rim. Offset and track must still comply with the requirements of this section. |
2ZR swap. DO IT! Ask how!
This is probably the best resource for determining what puts you in which class. Keep in mind that these rules are generally only enforced at the regional/national level, and your local events may choose to forgo them.
http://scca.cdn.racersites.com/prod/...lo%20Rules.pdf Which means using those wheels puts you in at least STF. |
#5 | |
![]() ![]() ![]() Drives: 2010 Yaris HB Blazin' Blue Join Date: Feb 2011
racerb
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 |
Thanks for the info guys! So it looks like 14X5.5 with +30 to +40 offset will work. Any recommendations on tire pressures?
09 Yaris S 85 Corolla GTS Last edited by kwkshft; 02-26-2013 at 06:56 AM. |
#7 | |
see this link from Tire Rack http://www.tirerack.com/tires/tirete....jsp?techid=58 good luck and enjoy the extra grip! Steve |
#8 | |
I put higher pressure in Garm's rear tires (higher than what he normally runs), and coached him a tad, and he dropped a good amount in some autoX runs. Total of almost 2 seconds on sub 50 sec course. |
Mmm, 14" r-comps on stock steelies
Be very careful on R-Compound tires with stock struts and shocks, these tire grip so well they can create bicycling on tighter auto-x courses. Work up to your limits until you are ready for suspension upgrades and you will be much happier in the long run. Also a very good way of checking for proper tire pressure is to put a couple 1"-2" long lines of white shoe polish on the tire shoulders. It's very easy, if your scrubbing the entire line off, then up your pressure, if your not even touching these lines, lower your pressure, it's that simple. Oh and some crash bolts for negative camber in the front suspension from Micro Image, will be a huge improvement!
racerb
hehe
i like that red car with the r comps! |
#12 | |
09 Yaris S 85 Corolla GTS |
im guessing he means TWO wheel action
#14 |
bicycling = 2 wheels
#15 | |
#16 |
Yeah I have seen it on several occassions where cars would actually get up on two wheels due to higher grip than suspension could handle. There are lots of videos of it on Youtube, check it out to see what I mean!
Here is one example...http://www.youtube.com/watch?v=A0hTl78eaI8 racerb
#17 |
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
If you need more wheels rolling into your grarage I have stock steel wheels with 205/50-15 falken azenis 615's on them. I was planning on getting them out to measure tread to post up to sell.
#18 |
| wider stock wheels ? | larryn2o | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 01-24-2011 09:49 AM |
| Converting from Custom Wheels back to stock!!! | daddz07 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 09-23-2010 08:45 PM |
| Stock Wheels 15' and Black Stock Hood (SoCal) | White Yaris | Items for Sale by private party | 9 | 01-07-2010 12:39 AM |
| changing stock wheels? | bribri | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 06-30-2009 10:30 PM |
| FS: Stock steel wheels and hubcaps | letstry1234 | Items for Sale by private party | 0 | 06-22-2009 12:31 PM |
