Old 02-27-2013, 11:22 PM   #1
Kar98
Drives: 2011 Scion tC
Same speed. The "high" mode is the normal speed. The "low" mode, if implemented with the Prius module, keeps it moving at the same speed, but adds a non-adjustable time delay between swipes.
I wouldn't mind that ;)
Kar98 is offline   Reply With Quote
Old 02-28-2013, 06:39 AM   #2
You can have that with my intermittent rear wiper module. It takes advantage of the extra switch position, which is not implemented when you install a Prius wiper on a Yaris. I can build the module where the delay is adjustable (where it has a potentiometer that you mount to the dash) or where it is a fixed delay (where you simply bury the module under the dash and forget about it).
www.yarisworld.com/forums/showthread.php?t=43568
variable intermittent wipers thebarber Cosmetic Modifications (Exterior/Interior) 27 10-18-2022 03:26 PM
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 10:39 AM
Making Intermittent Rear Wipers ttufrosty Cosmetic Modifications (Exterior/Interior) 1 08-12-2007 10:57 PM
