Old 03-01-2013, 11:36 AM   #1
daveg7
Drives: yaris
Firstly thanks for the Help CTScott
When I disconnected the ECU and turned the engine the fuse did not blow and the centeral locking system from the key fob works ok.
Does this surgest that the receiver, amplifer and body ECU are ok?
And would i be able to reprogram the new ECU to the keys using the manual key reprograming method that is used to add new keys? I have no clue what a toyota service tool is.
daveg7 is offline   Reply With Quote
Old 03-01-2013, 12:31 PM   #2
That is actually a good sign. Without the ECM being alive you can't tell yet if the key amplifier is OK, but hopefully with the others being OK it is as well.
For programming the keys, I am not sure about the 1st gen Yaris, but with the 2nd gen, to program new keys, without having an original "master key", a special piece of Toyota service equipment is required, so you would have to get the car to the dealer to have it reprogrammed (and of course it won't actually start until you do so).
Since the ECM is definitely bad, take it out, remove its cover, and lets see if there is visible damage. Sometimes there is a sacrificial component that will pop with reverse polarity and simply replacing that one component will bring the device back to life.
Old 03-01-2013, 01:58 PM   #3
daveg7
Drives: yaris
thanks i will try and take it off tomorrow when it light and have a good look.
Old 03-02-2013, 05:00 AM   #4
daveg7
Drives: yaris
Hi I have taken the ECU off and opened it up, and can see no apparent damage at all. what does this mean?
Old 03-02-2013, 06:32 AM   #5
It could be that what was damaged did not catastrophically fail. Can you snap some pictures of the inside?
Old 03-02-2013, 09:57 AM   #6
daveg7
Drives: yaris
if you need any close-up's of different areas just say.
If the ECU is ok could it be the connection cable?
Auto insurance issues from modifying a Yaris? RMcG General Yaris / Vitz Discussion 11 06-24-2012 04:38 PM
Just bought a 2010 Hatchback AT and having some issues Dissolutus New YARIS Purchase Forum 9 03-19-2010 10:46 PM
CV joints or axel issues aucorium DIY / Maintenance / Service 1 02-17-2010 09:10 PM
For the TEIN S tech users any sagging issues? marcus Performance Modifications 7 01-28-2010 04:06 PM
Exhaust clearance issues... YaYa1320 Performance Modifications 12 10-07-2009 04:46 PM
