Old 03-03-2013, 12:23 AM   #1
My street setting is 14psi also, very usable. I have my second map on a toggle switch in front of me, can switch on the fly.
How do you switch between maps, and do you have two or more than two?
Old 03-03-2013, 10:45 AM   #2
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
It's all one map, tuned up to 30psi. I have a trueboost boost controller, can change preset boost settings in seconds.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 03-03-2013, 01:14 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
After waiting 5+ years to actually not only see Garm's LB, but get to ride in it seeing him use the toggle was pretty enlightening on how easy that setup can be used. Really put things into perspective on what to expect once I get into the HP realm that you (Blown and Garm) are sitting in. From Cranky's estimates I will need to be at roughly 400hp myself to get to my loftiest goal if I can ever get the damned finances straight enough to do so!
