Old 03-04-2013, 03:49 AM   #1
TOLMACH
Drives: soarer
Intercooler for non-turbo?
Need opinions on adding the intercooler for non-turbo car.
Smth like below
http://www.ebay.com/itm/ALUMINUM-BAR...fb4fb5&vxp=mtr
Technically, the project is pretty straightforward: I already have a TRD cai which goes under the fender, extending the tubes to the radiator and placing the filter further under the opposite fender is not difficult.
Any potential gains? Cons?
Thx
Old 03-04-2013, 09:29 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
lol. no gains.
It's the same thing as extending the piping to the center and placing the filter in the center instead of under the fender.
Cons? Extra baggage that you don't need. Longer air travel. Looks ghey when you open up your hood and don't see a turbo.
Old 03-05-2013, 09:42 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
zero upside, and it can only make the air warmer, which will reduce hp.
Colin Chapman disciple
Old 03-05-2013, 10:04 PM   #4
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
better off getting the turbo encabulator
Old 03-06-2013, 09:43 AM   #5
Intercooler with a turbo makes sense because boost is created by hot exhaust gas, and because the air is compressed. Boost from a supercharger also compresses the air; compressed air gets heated up. I don't see much point in a "normal" n/a application.
Old 03-06-2013, 10:12 AM   #6
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I have seen extreme guys use an air/water intercooler and actually put ice in the intercooler (with a turbo) to decrease temps even further though I agree that gains would be minimal and probably not even noticeable.
Old 03-07-2013, 12:15 PM   #7
bebeelo
ThatYarisGuy
Drives: Toyota Yaris 2012 SE
what he said ^
bebeelo is offline   Reply With Quote
Old 03-07-2013, 06:39 PM   #8
why?
why?'s Avatar
Drives: Yaris LB
on a drag strip with track temps hitting 100 degrees, ice everywhere will help.
Old 03-07-2013, 08:05 PM   #9
yaris2010RS
yaris2010RS's Avatar
Smth like below
Thx
I would have to disagree with everyone in this thread.
I do believe I am the only one who has actually installed an IC on a non-boosted yaris. although i did not dyno it the ButtDyno did notice a difference.
Also with my OBD2 scanner, I was noticing IAT lower then with just my intake.
Also i noticed possibly due to the longer intake/bigger filtered air volume the car seemed more peppy.
keep in mind i am not claiming HUGE hp gains, but definatly noticed a difference. And it looks dang cool
Old 03-08-2013, 01:07 PM   #10
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
How can the intake air be any colder than ambient temps? A proper COLD AIR INTAKE is drawing in air at ambient temps, so adding an intercooler will only add restriction REDUCING hp.
Old 03-08-2013, 01:17 PM   #11
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I think intake air should be routed through the air conditioner.
Old 03-13-2013, 07:43 PM   #12
MUSKOKA800
MUSKOKA800's Avatar
Now you're talking!
Any other ambient cooling of ambient air is just a waste of hardware, added weight and added restriction.
I can smell the RICE cooking!
Old 03-08-2013, 02:57 PM   #13
TOLMACH
Drives: soarer
The problem is that there is no proper air intake on the market that would draw air at ambient temperature.. to achieve this air would have to be drawn from in front of the radiator
Old 03-08-2013, 04:19 PM   #14
BEEF
BEEF's Avatar
I know my SRI air temps usually run about 5 degrees hotter than ambient (as per my ultragauge) so I don't think you will really see much of an improvement with that small of a difference. think of driving on a cool summer day vs a warm summer day.
Old 03-08-2013, 04:44 PM   #15
TOLMACH
Drives: soarer
5 degrees difference sounds negligible
thanks
I guess I need to find the way to measure temperature near the air filter (I use TRD intake) as compare it to the ambient temps myself
Old 03-08-2013, 06:24 PM   #16
7:34pm
Drives: 07 Yaris
I don't think in my 10+ years of browsing car forums that I've come across such a topic... wow
7:34pm is offline   Reply With Quote
Old 03-08-2013, 08:38 PM   #17
BEEF
BEEF's Avatar
If your car has the outside temp gauge and you have a scangauge/ultragauge it is really easy to compare the two.
I will admit, it is a very strange topic. we do try to squeeze every bit out of these cars. I think it is good to think outside the box from time to time. sometimes you find something new, sometimes you don't.
Old 03-08-2013, 09:31 PM   #18
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Reminds of the motorcycle rider who bought a can of NOS from 7-Eleven and poured it in his gas tank.
FS : GT2560R Turbo + Manifold Parmas Items for Sale by private party 0 08-24-2012 08:35 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
