#19 | |
play every day
Why not simply go to a non-CNC machinist? It's just a simple square piece of aluminium with 5 holes drilled in it. You could make your own tapered bore with a half round hand file and some sandpaper, and buy some longer metric bolts to hold everything together. I port match my flanges with a 30 year old Dremel and sandpaper... ![]() There's another slightly more involved alternative. Cut off the existing flange with a hacksaw and have a welder weld a plate onto the casting. It's just soft aluminium. I had considered doing this on the tooters but it added an extra production step and more cost. |
#20 |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
Since the intake on the blitz is smaller than the diameter of the 1zz TB anyway, will there be enough of a benefit to justify the labor required to make these adaptors?
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
#21 | |
play every day
![]() In my opinion it would work because the intake is not passive. The supercharger is actively pumping air creating pressure in the head rather than the normally aspirated vacuum. So it's actively pulling in air through the intake casting and the throttle body. The butterfly in the throttle body is what controls the engine speed through metering the intake air. So a larger butterfly can meter more air. Even though the intake is smaller, the air will move at a higher velocity and at a higher manifold vacuum. |
#22 |
I'll definitely be interested to see what comes of this.
#23 |
play every day
#24 |
2ZR swap. DO IT! Ask how!
I'll be back on the engineering campus this summer, so it would be fairly easy for me to fab up an adapter plate. I'm also going to talk to the prof. in charge of the casting equipment to see if I can learn how to use it.
#25 |
I'd like to hear CTScott's take on this. He's been running a S/C for a while now.
#26 |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
Definitely interested with the adapter , cranky. Hook a brother up :)
#27 | |
play every day
![]() Heck, you could do it with just a drill press, a hack saw, and a hand file. |
#28 |
lol, I've made a few small gun parts with hand files... I can't even imagine how much work one of these would be.
#29 |
play every day
Aluminium is soft and really easy to work with, and the supercharger adaptor is just a piece of metal with some holes in it. I'm already hacking up a manifold just to see what will happen...
#30 |
^ agreed. Super easy to make an ugly one just to test it.
#31 |
Agreed, though I would have a hard time using anything less than a knee mill. All of this of course pivots on me getting another 1ZZ TB, since the first one was given an autopsy to see how it goes together.
#32 |
Looks like TOLMACH went and put an xB supercharger on his, and used the Tooter TB adapter to make it fit: http://www.yarisworld.com/forums/showthread.php?t=42913
#33 |
Some musings in CAD. I've got a block of 6061 in mind for this, just have to make time in the shop for it...
#34 |
play every day
While most of my concepts never make it to reality, this 1ZZ bellmouth adaptor actually did. It's 2 inches thick so there's plenty of material work with. And lots of room to drill a hole in the side to add the breather hose fitting.
$185 including shipping. When I had one made for the experimental tooter et, I also made one extra just to see if there would be any interest in a Blitz 1ZZ Adaptor.
#35 |
My goal with this design is to use a 90° silicone reducing elbow (2.5" -> 2.25" or 2.0") or something of that sort to connect to the Blitz. I think that the xB intake tube would be ideal, since it's already cut and round, but convincing someone to swap could be difficult.
#36 |
play every day
An adaptive slip on coupling is a good idea, Cranky.
| BLITZ supercharger kits IN STOCK | cali yaris | Micro Image | 34 | 06-02-2012 10:31 AM |
| FS: blitz supercharger kit + camcon | vten | Items for Sale by private party | 20 | 02-22-2012 09:12 AM |
| Blitz supercharger and everything else. 56K beware | camelll | Items for Sale by private party | 23 | 05-06-2011 09:32 AM |
| gap for spark plugs for the blitz supercharger? | whooppee777 | Forced Induction Forum | 2 | 03-12-2011 01:09 PM |
