Old 03-30-2007, 08:44 AM   #1
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
I was looking into the idea of getting this, but i came across the idea of the programable Keyless/Sec. System, that has different settings for items, such as windows: Example: A Lexus has the windows set to lower 10% to let heat out of the vehicle when you open the doors to the vehicle, I thought that was pretty cool.
I dont know if they have any setups like that, not to mention has anyone tried to setup an electronic switch in the hatch of the yaris to open with a hit of a button, for say on the keyless? Automatic lift-gate? Just put some heavier duty cylinders to open the gate from close to open?
Old 03-30-2007, 10:03 PM   #2
Dragonacc
Drives: 07 Yaris LB, 70 Mach 1, 84 5.0
It's possible that you are describing something else, but as a FYI -
When you open the door on a car and the window rolls down and then it rolls back up when you close the door, that's because the door is supposed to seal better/easier that way.
I need to look into getting this system, especially if it's plug and play.
Dragonacc is offline   Reply With Quote
