Old 03-07-2013, 12:55 PM   #1
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I am not sure if garm commented earlier in this thread but you can get pistons from him in a variety of thicknesses (compression ratios) so the big reason to use the prius pistons would be to save money.
I can't remember exactly what he said he had but it seems like he had 9:1, 11:1 and a 12:1. I may be a bit off on that one but you could ask him directly.
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
Old 03-07-2013, 01:12 PM   #2
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Saving $$$ is the idea... otherwise your correct you can get Arias Pistons with the CR ratios of 9:1 - 14:1 for the 1NZ...
Basically I just need the Cams and Cam gear with EMS...and I can test out this "prius Pistons" theory - not only will I get a bump from swapping cams from 1NZ-FXE to 1NZ-FE (stock 78hp to 108hp) ..but I should get a small boost from the 10:5 to 11:1 CR increase. I am sourcing a full 1NZ head now.
JustDidIt is offline   Reply With Quote
2010 Prius tuckevalastin Off-topic / Other Cars / Everything else Discussions 60 01-13-2009 12:24 PM
Stupid prius KSIbucky Tracking, Racing, Auto-X Forum 11 09-25-2007 11:07 PM
ZPIracing Turbo Pistons ZPIracing Forced Induction Forum 22 05-29-2007 03:39 PM
And You Thought the Prius Was Expensive! redyaris Off-topic / Other Cars / Everything else Discussions 5 05-18-2007 05:11 PM
Toyot Prius YamilR Photo-Video-Media Gallery 4 02-14-2007 06:54 PM
