Old 03-08-2013, 07:39 PM   #1
shameer_k
Drives: yaris sedan
I would check the connector first. Remove the lower steering column cover and you'll see the connector at the base of the switch. Wiggle each wire a bit with the switch in the parklight position and see if anything changes.
I know it's has been a while since I replied, but the lights began to work on its own. Recently it got worst. I tried everything you said but still no positive results.
I got a headlight switch from a crash yaris to try. Good new was that it worked. But I was wondering how difficult would it be to swap this part.
shameer_k is offline   Reply With Quote
Old 03-08-2013, 07:59 PM   #2
Headlight switch is not all that bad to replace. It does require removing the steering wheel and clockspring though. Here's a video of mine that shows what is involved:
https://www.youtube.com/watch?v=LgWS...gpsDA&index=17
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 04:11 PM
