No spacers at all. Offset +35 will is pushing the wheel outwards 10mm more than stock wheels which are offset +45. With +35, you'll be sitting close to flush with the wheel wells.
#2 | |
OP, if you had 14's, then it'll be 14x5, ET45. So a 17x7, ET35 rim will push the rims out 35mm (about 1.5" I believe). If you had 15's, it'll be 15x5.5, ET45. So those 17's will push it out 29mm from where you're at now. |
