Old 03-13-2013, 01:06 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
The measurment in the pic is slightly larger the actual diameter because it's at the expanded flange. The intake diameter at the MAF sensor is 2 inches. You can put anything else on either side of the sensor section...
...as long as right where the air passes through the sensor remains 2 inches.
Old 03-13-2013, 01:22 PM   #2
2.25" is stock, and is pretty much gospel to be the max. You can deviate under, but very rare is there any success going over 2.25".
Old 03-13-2013, 02:22 PM   #3
tooter
play every day
tooter's Avatar
I measured my stock air box and the two aftermarket intakes and they're all 2 inches at the sensor. The area in front of the sensor commonly increases to 2 1/4.
Intrestingly, this Injen appears to be larger than 2 inches at the sensor because it gets smaller between the sensor and the throttle body...
...although some intakes flare back out right at the coupling. My Simota intake tube is like that and needed a reducer to make it fit the stock throttle body...
The area in front of the Injen sensor looks to be at least 2 1/2 or even larger.
Old 03-16-2013, 06:31 PM   #4
7:34pm
Drives: 07 Yaris
ot: where can one get an aluminum pipe like that with the sensor adapter? I want to build my own intake.
7:34pm is offline   Reply With Quote
Old 03-16-2013, 07:04 PM   #5
tooter
play every day
tooter's Avatar
I bought the cheapest Weapon R intake I could find on ebay (about $160 at that time) There's one for sale now at $152 and free shipping. Then I sold off the foam filter, and hacked up the pipe so that I'd have the freedom to put anything in front of it that I wanted...
Old 03-16-2013, 08:02 PM   #6
hw6515
Drives: 08 Yaris AT, 350Z GT MT
Have u look on eBay?
http://www.ebay.com/itm/SUBARU-3-00-...47789a&vxp=mtr
hw6515 is offline   Reply With Quote
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
intake size lunarcrusader Performance Modifications 6 11-06-2009 02:20 PM
The great intake debate! fmicle General Yaris / Vitz Discussion 74 10-06-2009 11:37 PM
