Old 03-16-2013, 11:11 AM   #1
Eren_13
Eren_13's Avatar
Drives: Yaris SR '12
if you cant get an oven, when I cracked open the second gen headlights i pry'd them apart slowly and cut the glue with a razor blade as I was pulling, then when I was done I put them back together and ran the heat gun and applied generous pressure the them to re-seal the glue. :)
This might be an option. I can see the glue as I start to peel open the light but its just solid.
Originally Posted by Scubaru Steve View Post
if you flex the housing when its hot it may stay in that shape, so try to heat the glue evenly.
its funny when i did the ones on the echo, i had to use my friends garage for the bumper removal, then drive 30 mins across the city to use my oven. than drive back and install them tot he car and align. then use a heat gun to put them together.
Lol that sounds like a mission! I won't give up on this, don't you worry. I'll just give it a good, even blast with the heat gun. Then if all fails, I'll do the oven again with the door cracked I guess. These projectors will be worth all this though but man are they making me work for it!
Eren_13 is offline   Reply With Quote
Old 03-16-2013, 06:23 PM   #2
mr_miles
Drives: 2013 Yaris
Originally Posted by Eren_13 View Post
This might be an option. I can see the glue as I start to peel open the light but its just solid.!
I'd give it a shot! It's gotta soften up after some heat, I hope.
Tags
hid, projector, retrofit, yaris sr
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
