Old 03-18-2013, 12:56 PM   #1
HANZO_187
#CarFiend-HANZO188
Drives: 2011 Toyota Vios
Hey I keep hearing about the retro fit head lights. I wanna go with black housing and some day running lights. I just gotta know how the retro fit thing works out. I'm going for the all black look. Black emblem, black wheels, black head lights, and smoked out tail lights.
HANZO_187 is offline   Reply With Quote
Old 03-18-2013, 05:42 PM   #2
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Here is an example of a 2006-2008 Yaris retrofit
BlackFlameCustoms Inc.
But who wants to pay $895??
Here is a DIY that i followed..
How to: Mount Morimoto Mini H1 Bi-xenon projectors
Originally Posted by Courtesy of "usbseawolf2000" on PriusChat.com
Remove the screws highlighted in Red. See below.
Leave the ones highlighted in Green.
Headlight in the Oven. 265 deg F preheat and 7 minutes baked.
Headlight cover removed.
Remove the halogen H4 bulb cover. The bolt is in the back.
H4 bulb cover removed.
Mini H1 projector - Prepare it to look like this with the silicone rubber installed. Remove the H1 holder and the projector locking ring first.
Remove the high beam wires from the connector. Use a paper clip to push the two sides and it will slide through.
Snake the wires through the hole highlighted. You can see the rear of the Mini H1 projector.
Put the H4 adapter plate (comes with the projector) and screw the projector lock ring tight.
Silicone rubber sandwiched between the projector and the reflector.
How to: Mount Morimoto Mini D2S Bi-xenon projectors
Originally Posted by Courtesy of "F8L" on PriusChat.com
This tutorial outlines the mounting procedure for the Morimoto Mini D2S Bi-xenon projectors.
Step 1: Remove all hardware from backside of the projector except for the big silicone crush washer (white)
Step 2: Insert threaded shaft through the pre-existing H4 bulb hole in the back of your reflector bucket.
Step 3: Align the projector rotationally by adding the H4/9003 adapter plate on the backside of the threads. The notch on the inside should slide down the channel for it on the projector. Run the wires for the solenoid (and CCFL's in this case) in the small cavity off to one side that remained after removing the metal halogen bulb shield.
Step 4: Slide the black rubber o-ring over the threads. Ensure it does not get twisted during the process.
Step 5: Tighten down the whole assembly by threading on and torquing the threaded lock-ring. Be careful not to over-tighten or it may break. You only need to have 2-3 rows of threads left to work with after this goes on.
Step 6: Clean your D2S bulbs thoroughly and then insert into the back of the projector. The notches will only allow it to go in one way. Put the metal split ring washer over the back, as shown.
Step 7: Add the black o-ring over top the split metal ring. The angled side should face down.
Step 8: Lock the bulb in with the end cap. This only needs to be hand-tight to the couple leftover threads.
The projector is now mounted and aligned in your headlight. In this particular retrofit, the Gatling Gun shroud was pre-affixed to the projector using silicone. Typically though, you'll mount the shroud after the projector is clamped onto your reflector. The original reflector bucket was also painted black before the installation, to help reduce unwanted reflections.
JustDidIt is offline   Reply With Quote
Old 03-18-2013, 10:36 PM   #3
HANZO_187
#CarFiend-HANZO188
That is pretty much how I want mine...I'm down for the retro fit if its not too costly. If its too high then I might go with an alternative. But thanks you and Vten form the info and examples. Both are looking Awesome.
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 04:13 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
Glassylite Headlight Restoration Kit TEHxFALLEN V1.2 Photo-Video-Media Gallery 1 07-03-2010 12:51 AM
2B1 "6054" headlight upgrade? cali yaris Off-topic / Other Cars / Everything else Discussions 7 02-12-2010 10:24 PM
