Pimp had to replace his turbo...
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
fill this thread with all the questions and information you want as long as it isn't a complete distraction from a car based forum.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
^ Exactly. You could line up ten of those turbos, and no two would be built with the same tolerances.
If you like to roll the dice with your motor, go for it. I've never been comfortable doing it that way, but to each his own.
![]() ![]() Drives: 08 Yaris AT, 350Z GT MT Join Date: Feb 2013
OP, if you go the ebay route, could you document the parts you use?
Mr. 155 and climbing
Not to sound like a dick, but really you have a lot of knowledge here now about boosted applications on this car/engine on this forum and also MI. The quick and dirty is that you will NOT be successful in spending only 1k on a turbo set up. Period. Folks that have tried to go as low cost as possible have had failures on critical parts be it in a few months, less that a year, in between 1-2 years, etc.
Nobody out there would begrudge someone for wanting to go boosted on a budget, but this isn't going boosted on a budget. It is merely a formula for disaster somewhere down the road and depending on the disaster it could even be life threatening. When you go turbo especially you are taking a calculated risk, but that is the key word...calculated. How much do you want to put into the risk category is up to you. I can attest to what happens even with big name parts if they go bad as well as some other folks, but you are talking about leaving your engine and your life into the hands of folks that only has a single goal: putting cash in their pocket and taking it from yours. End of story. ![]() This isn't like buying the store brand macaroni and cheese as opposed to Kraft or Velveda. Just saying.
There is already a very good thread with all that info in it.
is there still a problem with the piping that would come in one of those kit, or the inter-cooler for that mater. I think we got the idea that the Turbo stand an 80% chance of being low quality and causing more problems than making power.
but but but Trubo wace carr
Then just do it the right way and pick up a Zage or pick up a used Zage, Management, Harness combo from someone and call it a day like we have been trying to tell you. We are trying to save you cash and pain.
![]() /out
yea, i know, but the excitement of possibly getting one sooner is what makes me want to go the alternative route. I guess i will just have to save up more and have it take longer to finally get there.
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
I am running a custom kit with a EBay turbo. It is a massive undertaking and I was a dealership ASE certified mechanic for over 10 years. The zage kit was not available when I went turbo so I built my own. My advise. Get the zage kit, a AEM FIC and a boomslang harness to hook it up.
#12 | |
^ more than $6k if you want it done right. If you want to do it stop thinking numbers and start buying parts needed.
#14 | |
some i'm sitting between many decisions. 1) start building my custom turbo kit for my car 2) doing option 1 in a manner as not to displease my wife 3) get something like an old Civic or Mustang to play with and let the Yaris stay as daily driver. 4) same as 2 but for number 3
Money your gonna spend to build a beater is way more then to boost a yaris.
if you want to keep your yaris as a boosted DD then i definatly recommend going with a zage or even the blitz SC. you can go the ebay way but you wont have a reliable DD and will be more work then fun. to save money you can get a zage and run around 5psi and you dont have to have management and FYI your wife will always be un-pleased if your buying stuff not for her....
you are going to have 3-4k alone in the top end to get you usable 300hp. You will hit the 6250rpm ceiling faster than you can blink believe me. I hit it quick as hell even at 8-10psi. The extra 800-1000rpm will make a decent difference. Your bottom end can run you easily 2k and now you are at your 6k mark without even boosting the engine.
^or a bolt on zage kit @5psi and you get to work just a bit faster and make it there everyday.....
If you have the money (and preferably the support of your wife), I don't see what you're waiting for. Buy a beater, find a local shop, and get a build going!
... But I may be a bit biased because I want to see a serious build
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Plan to install hks turbo kit on 1szfe | Faraz_Shaikh | Forced Induction Forum | 5 | 10-19-2010 11:00 AM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 01:24 AM |
| Garrett Turbo kit | elsteverino889 | Forced Induction Forum | 24 | 04-20-2007 10:27 AM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
