Old 03-19-2013, 10:27 AM   #1
hw6515
Drives: 08 Yaris AT, 350Z GT MT
I do have an excel sheet with most of the parts you will need for a full turbo kit, $1634 seems a bit low.
hw6515 is offline   Reply With Quote
Old 03-19-2013, 12:04 PM   #2
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
can i get a copy of that, should be interesting to look at and see what all i'm missing from the original post. I know there are a few things missing from the OP and i know that in order to make a good system low compression pistons, upgraded connecting rods, turbo timer, quality blow off valves, and probably an upgraded fuel system as well.
Old 03-19-2013, 12:09 PM   #3
hw6515
Ill post as soon as I get home, it was made with ebay stuff mostly. No engine rebuild.
Couldn't find the final version, but will look for it. (it wasn't completed though)
Old 03-19-2013, 06:07 PM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
What is your over all goal? This is the first and foremost question to be asked.
Old 03-19-2013, 06:46 PM   #5
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
The two most important things in a turbo kit, is the turbo and manifold. Expect to replace the Ebay turbo often. That particular size turbo won't bolt to the micro image manifold anyways. There is no easy/cheap way to boost a car properly, If you go that route expect much headache. At the shop I work at, I can't count how many times a customer brings us an $800 kit and leaves with a $ 5000+ bill.
Ptuning.com
Blown_xa is offline   Reply With Quote
Plan to install hks turbo kit on 1szfe Faraz_Shaikh Forced Induction Forum 5 10-19-2010 11:00 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
Garrett Turbo kit elsteverino889 Forced Induction Forum 24 04-20-2007 10:27 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
