Old 03-19-2013, 11:31 AM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
no problem
its a common 'marketing' flaw with Magnaflow converters that they are all 'high flow' when they are not. They just starting making universal high flow 300cell per square inch about a year/1.5 ago. Which is a mild upgrade over stock, but not much & it will need to be welded in.
alot of new cars now even feature higher rated cores from the factory, with 600, 800, 1200 cpsi to which a "standard" 400cpsi core would then be considered "high flow". but in terms of our yaris, they use 400cpsi stock.
My shop we carry 100, 200 & 300cpsi higher flowing converters & i show people the difference & they are usually floored!
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 03-19-2013, 08:40 PM   #2
TOLMACH
Drives: soarer
Originally Posted by malibuguy View Post
no problem
I wish you were closer to BC canada ((((((((
Old 03-20-2013, 12:09 PM   #3
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
...and I wish that malibuguy was closer to Malibu.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
High Performance MAF LittleRed Performance Modifications 3 05-24-2011 01:13 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
