Old 03-20-2013, 06:55 PM   #1
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
More gears can allow you to either use the most efficient rpm range, or the most power range. More gears, depending on the engine can improve FE. It is going to depend on the driver (if it is an stick), or the ECU to make use of the gears. Also, a car with extra gears can have a higher final ratio, without hurting performance. I would love to have a six gear as I would love to see my rpms sitting a little lower when driving 70. Of course, geared that high I would have to downshift more often, but I would have paid more for one more gear if that was an option.
More gears, the closer the ratios can be, and still have a good final ratio.
I was nearly ready to by a different make car in a six speed auto, as I thought it would be efficient enough. I was not willing to buy the four speed automatic, as it was likely to cut into the FE too much.
I think the reviewers are right, customers want at least a five speed in an automatic, as it can improve performance or FE, depending on how it is driven.
Amdkt7 is offline   Reply With Quote
Old 03-21-2013, 12:09 AM   #2
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Your missing the point. Your final gear ratio is what gives good mpg. You could have 4,5,6 or 7 speed, but if the final ratio is .7 mpg will be the same.
Now if you talking about a Bugatti or Ferrari with a top speed of 250 mph, than of corse one would benefit from a 7 or 8 speed.
But in the world of 100hp econo cars, 4speed auto is plenty. imo.
UberSilver is offline   Reply With Quote
Yaris vs Celica jesh462 New YARIS Purchase Forum 11 10-18-2012 11:49 PM
