Old 03-21-2013, 08:56 AM   #1
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
Originally Posted by UberSilver View Post
I was about to state something similar. More speeds in the same sized box= less robust build. If the top gear(OD)is .7 ratio, extra speeds is just marketing.
In the 60's Yamaha had a motorcycle with an 18 speed gearbox. Now most bikes are 5 or 6 speeds.
In the 60's, most bikes were 2 cycle, they had a very narrow power band. They needed a lot of gears. Now they have 4 cycle engines, and a much better power band.
Again, my point is I want a higher final ratio.
Amdkt7 is offline   Reply With Quote
Old 03-21-2013, 12:01 PM   #2
UberSilver
UberSilver's Avatar
100% correct! And the Yaris is a 4 cycle with a wide power band, not needing more than 4 speeds in the auto.
Also, todays 2 cycle motorcycles are 5 or 6 speed.
Again, my point was the final ratio is no different if you have a 4, 5 or 6 speed auto.
The final (OD) ratio is also .7 on the Ford Fiesta 6 speed auto. Same as the Yaris.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
Yaris vs Celica jesh462 New YARIS Purchase Forum 11 10-18-2012 11:49 PM
