Old 03-24-2013, 01:59 PM   #1
racerb
I have Road Raced lots of different FWD racecars over the years all using stock brake calipers. Your best money spent is on good pads (Hawk/Carbotech), rotors (Brembo,R1 Con.,Centric), brake lines (Goodridge,Stoptech), oh and as others have said proper cooling. Good quality fluid is a must, we always ran Castrol Dot 4/5, but any good fresh fluid bled often will make a big difference. A good set of Speed Bleeders will make life easier when optimizing long time brake performance.
http://www.russellperformance.com/mc/speed/import.shtml
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 03-24-2013, 09:11 PM   #2
Yarflana
Drives: 2008 Base Model
racerb
Yeah, that's what I decided. On order right now from MI are R1 drums, rotors (drilled and slotted), shoes, Hawk pads, and a racing battery. I already replaced the break fluid with Motul 5.1 and put on stainless lines and adjusted the e-brake.
As of now, with just the new fluid, lines and e-brake adjustment, my pedal is twice as firm and 50% less travel in the brake pedal. With the new pads and shoes, it will be unbelievable I am sure and I won't have to mess with brake fluid bleeding again for a while.
Thanks for all the responses on this. I don't think I would have paid $500 for 4 piston calipers anyway, even if they were "double" the performance.
Yarflana is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
OEM roof rack mounting rubber pad replacement Yai Cosmetic Modifications (Exterior/Interior) 3 12-22-2012 12:01 PM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
DIY: Painting Factory Brake Calipers redyaris DIY / Maintenance / Service 38 05-26-2007 08:47 AM
