![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
play every day
I had a small cylindrical neodymium (really strong) magnet and simply drilled a hole in the drain plug with a drill press and glued it in with JB Weld. Small magnets are readily available on ebay at very reasonable prices.
At every oil change, I wipe off the extremely fine black metallic residue attached to the magnet. That's the thing about magnetism, there is no size limit on the ferrous metal particles attracts and captures. The residue is so fine that when you rub it between your fingertips, you can't even feel it. Magnets on drain plugs are common aftermarket items installed on motorcycles where the transmission and engine share the same oil reservoir. |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| Shell conventional ( $2.17 ) / synthetic ( $3.17 ) at BJs Wholesale : 5/31 > 7/4/12 | Hershey | DIY / Maintenance / Service | 4 | 08-14-2012 12:04 AM |
| SHELL conventional / synthetic : $9 off a case at BJs Wholesale | Hershey | DIY / Maintenance / Service | 1 | 03-25-2012 11:12 PM |
| BJs Wholesale : SHELL conventional or synthetic $9 off a case ... | Hershey | DIY / Maintenance / Service | 1 | 01-24-2012 11:42 PM |
| Used Oil Analysis : SHELL full synthetic 5w-30 (SN/GF-5 ) in the '08 sedan | Hershey | DIY / Maintenance / Service | 4 | 09-23-2011 12:54 AM |
