Old 03-26-2013, 01:28 PM   #1
Eren_13
Eren_13's Avatar
Drives: Yaris SR '12
It is fine to change them all. If you only changed the front or only the rear, you could possibly get away with not needing the load resistors, as you would still have a set of high wattage bulbs in circuit.
Oh right, I didn't think of it that way. So using reverse logic, could that mean that because I have the load resistors on the front, it be that if I put LEDs in the back without resistors, would the front resistors still be taking the high wattage and therefore take away the need to install load resistors at the back or does it not work that (oh so simple) way?
Eren_13 is offline   Reply With Quote
Old 03-26-2013, 02:21 PM   #2
The front and rear bulbs are connected together, so you should only need one resistor per side on either the front or back.
DIY Cruise Control for 2012 Yaris - Good News! CTScott Third Gen Yaris General Discussion 305 10-27-2025 01:52 PM
2012 Fog relay Absolutely Red 12 Third Gen Yaris General Discussion 70 01-16-2016 06:41 PM
2012 Yaris + Tanabe RnD Pics zackt69 Performance Modifications 14 03-16-2013 08:41 AM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
First Drive: 2012 Ford Focus Kal-El Off-topic / Other Cars / Everything else Discussions 18 02-25-2011 05:41 PM
