Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
i tested the fog lights in class today and their is only a maximum of 150 mA. since i didn't think it right to ask for another switch I installed a toggle switch, which worked until i had the head lights on, then it broke again... not sure what the hell i did but as far as i can tell the fog lights are wired into the correct places but still I brake it.
anyone got a schematic of the OEM fog light circuit for the 09 Yaris 3 door? maybe i can trace and ponder a solution.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#2 | |
The kit fog light switches failing is likely a failure of not the switch itself, but rather the circuit that bridges illumination and that switching to ground of the relay. On an OEM setup the illumination and switching occur via two separate circuits. Was your toggle switch an illuminated one?
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| LF: Yaris switches | carrera2 | Willing to Buy by private party | 0 | 07-11-2009 05:10 AM |
| Power Window Switches | Stoln | Australia | 5 | 11-07-2008 09:02 AM |
