Missfire is either mechanical / electrical / or fuel related. If the missfire happens when its more under load then its usually electrical such as a coil. One way to test it is remove the coil from cylinder 4 and switch it with cylinder 3. See if it sets a code p0303 then its a defective coil. If it still sets a code p0304 perform a compression test on cylinder 4 to eliminate burn valves or ring issue. At that point with process of elimination you know you have a stuck injector. You could try chevron fuel system cleaner or a bottle of seafoam in your tank and hope for best. Otherwise it will need to be replaced.
| random pic | smofskra | Photo-Video-Media Gallery | 3 | 06-04-2011 10:53 PM |
| P0300 Random / Multiple Cylinder Misfire DetectedCylinder 3 misfire | dante2086 | DIY / Maintenance / Service | 4 | 05-15-2011 04:36 PM |
| FS: Bnew Porter Cable 7424 Random Orbit Polisher - NJ | jeff_o | Items for Sale by private party | 3 | 01-30-2010 07:53 PM |
| Random feature | Kaotic Lazagna | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-17-2006 05:24 PM |
