Old 03-29-2013, 09:27 PM   #1
metalshark
MetalShark
Drives: 2008 Yaris LB
Accessory belt noise
Today I installed a new belt from the Toyota dealer on my '08 Yaris. The Toyota belt has a fuzzy fabric type surface on the Vees side of the belt. My car still makes the bad bearing noises. Using a Harbor Freight stethoscope I checked the water pump bearings, the alternator bearings and the AC clutch hub bearing. They were all loud but the water pump was the worst of the three. It's not leaking......yet. $23.04 delivered from Rockauto.com. Does anyone know where to pick up new bearings for the alternator?
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Seat belt buzzer is silenced billk General Yaris / Vitz Discussion 48 10-30-2013 09:58 AM
new serpentine belt dferguson2 DIY / Maintenance / Service 1 06-30-2012 08:07 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
Rough Idle in drive toyoman NY / NJ/ CT / PA 8 04-22-2007 03:40 AM
