![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
why are you bleeding it on the master cylinder end? the air inside the lines will still be there if ever. bleed it on the end of the line near the brake cylinder/wheel you serivced, do what 's called "pump-pump-pump-stay".
HTH. |
#2 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
old style
You can still bleed them the old style as long as you know what you're doing and have good communications between yourself and the fellow doing the pedal pumping. The way you would move the master piston too far is if you keep pumping while the bleed valve is still partially opened, good communication and one pump and hold at a time works pretty good. Done that many times in all my cars, my 2 cents on this......
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
| another brake question | swidd | DIY / Maintenance / Service | 10 | 06-20-2010 05:51 PM |
| brake question | stuffy | DIY / Maintenance / Service | 12 | 06-18-2010 05:04 PM |
| Help Needed - Brake Light Question | *MAD DOG* | Cosmetic Modifications (Exterior/Interior) | 21 | 02-08-2009 05:32 AM |
