Old 04-01-2013, 04:47 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I'll let you know how the Rivals are, I just bought a set of 205/50/15.
Old 04-01-2013, 05:32 PM   #2
racerb
Yeah I was going to suggest the 205s for our cars, 225s seemed alittle bit wide for the Yaris! I ran 205s on my 2,600 lbs. Celica without issues, I'm sure our 2,300 lbs. of Yaris want overwhelm them!!
http://www.tirerack.com/tires/tires....5GFR&tab=Sizes
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 04-01-2013, 05:54 PM   #3
xnamerxx
0-60 in slow
xnamerxx's Avatar
Its not that the tire is wide its that my rim is only 7" wide so going wider is just a weight penalty and a loss in transitional grip.
Old 04-01-2013, 06:06 PM   #4
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I swear by TOYO tires. You folk in soCal may not have this issue, but I had a heck of a time getting heat in Hankooks ( on rear) during early spring and fall events. I had to drive 70% to keep rear from coming out on me. I consider myself a serious competitor in NASA Mid Atlantic Autocross Series, I went from running Hankook Z214 c71 compound r- comps, to TOYO R1R street tires. So far ( 2 events into the season) I have made the right choice. 1st event was in 40 degree temperature, 2nd was in the rain. TOYO R1Rs are BEAST in the rain with at least 2\3 tread. You can run 100% without even warming them up, compound stays soft in cold or wet.
TOYO RR's (40 treadware) are available now http://toyotires.com/tire/pattern/pr...petition-tires , if the compound properties are similar, these will be the tire to beat. Mark my words.
Also, you have to look at what the quick SMF guys are doing...... saying '' 205s are ok on my 2600lb car are ok so....'' just isn't gonna cut it ( if you want to be competitive ) . Brian Karwan is a local to me, he is the national SMF champion , sub 2000lb car running 275's in the front . 225's in rear (narrow to get heat) . Nobody can touch that guy. I mean his setup goes way beyond tire choice , but that is an example .
I personally choose not to run my local SCCA events because the organizers take the fun out of it and think they are running a F1 race, and generally the competitor's are uptight.
When I do run with them, I am competitive .... But Brian Karwan is untouchable.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 04-01-2013, 09:57 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Excellent. Again, I'm not building for SMF--that's just where the S/C puts me. My suspension also isn't set up for R-comp levels of grip (tokico blues/S-Techs/no camber adjustments) because I also DD the little bugger. Anyway, looking forward to seeing how they run!
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
2007 Yaris bad tires weaver615 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-27-2010 07:21 AM
