Old 04-01-2013, 06:34 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
in cold temps the Toyos work, I just hate hate hate the way they feel when driving, plus I have an exuberant driving style and I'll overheat tires through a run. Generally here in SoCal we have 70+ second runs and the Toyos don't seem to hold up all that well at least with my $hit driving. We don't normally see track temps below 50 degrees here, but if you have right setup, toyos are really really hard to beat.
If I was buying a tire for SMF I'd look at R comps and 245 minimum in the front and a 8-9" rim but and this is a big but I don't know a damn thing about SMF setup so yeah.
Old 04-01-2013, 09:20 PM   #2
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
That is very strange that you overheated them in a single autocross run, I ran 30 minute track sessions on them and proved to be very very consistent. Maybe you aren't running enough camber? I run -3 degrees at least. Im guessing you toasted the outside?
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 04-01-2013, 09:27 PM   #3
Jason@SportsCar
Count the number of turns in that 30sec run versus your lap. Autocross puts a much bigger hurting on tires than the average road course.
Old 04-01-2013, 09:58 PM   #4
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Never thought about it like that. What is the difference between a autocross compound vs road course compound ? c51 vs c71, a6 vs r6? I was under the assumtion autocross compound took to heat quicker ? If so, Im lost
Ptuning.com
Old 04-04-2013, 11:23 AM   #5
xnamerxx
0-60 in slow
xnamerxx's Avatar
Autox compounds don't require heat or as much of it to work. Makes them good for Time Trials and such where you don't get 2-3 laps to heat them up.
So I've had the Rivals on for a day or two and I'm kinda on the fence about them. They are certainly good tires and have quite excellent grip, but I can't seem to get them to breakaway like I want, I'm not sure if that's a good or bad thing.
I've also been unable to induce massive tire squeal that most others have so I may not be pushing them hard enough yet, but I have seen 1.18g on them right out of the box during a test run whiich is pretty amazing.
Old 04-01-2013, 09:49 PM   #6
xnamerxx
0-60 in slow
xnamerxx's Avatar
I have -3.5 on camber and 0 deg toe.
Ran 2 track days back to back on em and they didn't overheat, but I'll overheat them easily halfway through an autox run. I'm a pretty exuberant driver (aka bad) and I have big issues with inside spin so I can overheat Toyos without trying. According to my temp data I toast the middle and my wear pattern seems to say I'm using to much pressure but I don't like going below 29 psi.
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
2007 Yaris bad tires weaver615 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-27-2010 07:21 AM
