#1 | |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Ptuning.com |
#2 | |
Autocross puts a much bigger hurting on tires than the average road course.
Never thought about it like that. What is the difference between a autocross compound vs road course compound ? c51 vs c71, a6 vs r6? I was under the assumtion autocross compound took to heat quicker ? If so, Im lost
Ptuning.com |
#4 | |
0-60 in slow
Autox compounds don't require heat or as much of it to work. Makes them good for Time Trials and such where you don't get 2-3 laps to heat them up. So I've had the Rivals on for a day or two and I'm kinda on the fence about them. They are certainly good tires and have quite excellent grip, but I can't seem to get them to breakaway like I want, I'm not sure if that's a good or bad thing. I've also been unable to induce massive tire squeal that most others have so I may not be pushing them hard enough yet, but I have seen 1.18g on them right out of the box during a test run whiich is pretty amazing. |
#5 | |
0-60 in slow
I have -3.5 on camber and 0 deg toe. Ran 2 track days back to back on em and they didn't overheat, but I'll overheat them easily halfway through an autox run. I'm a pretty exuberant driver (aka bad) and I have big issues with inside spin so I can overheat Toyos without trying. According to my temp data I toast the middle and my wear pattern seems to say I'm using to much pressure but I don't like going below 29 psi. |
| Best all-season tires for the Yaris? | Rahxephon | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 03-17-2013 06:40 PM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
| 2007 Yaris bad tires | weaver615 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-27-2010 07:21 AM |
