#1 | |
The recessed area in the center is where the bulb is located. 1/4 turn with a flat head screwdriver releases it. Bulb Installed.jpg And, this is what the bulb assembly looks like when removed: Bulb Removed.jpg
#2 | |
![]() Drives: Yaris Sport 2014 Join Date: Jan 2014
The green is just a sleeve on the bulb. I am not sure if you can find the bulb with other color sleeves, but you may be able to find replacement LED bulbs of that same mounting.
| Tags |
| climate bulb replace |
| The electronic climate control displays | mrbond | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 04-18-2021 03:34 AM |
| Digital Gauges, Auto Climate control, Manu-matic shifter | computerlove87 | Cosmetic Modifications (Exterior/Interior) | 21 | 12-02-2012 11:55 PM |
| Yaris 09 climate control lights | alt_k1ll3r | DIY / Maintenance / Service | 2 | 11-11-2008 10:19 PM |
| Bulbs For Behind The 3 Climate Control Knobs | razzorjet2 | DIY / Maintenance / Service | 2 | 04-06-2007 10:41 AM |
