Old 04-06-2013, 09:39 PM   #1
bcat37645
Drives: 2dr Hatchback
CTScott, thank you. I suppose it's not accessible by simply pulling the knob off...??? I bet the entire panel must come off...!!!
bcat37645 is offline   Reply With Quote
Old 04-06-2013, 09:44 PM   #2
Correct. The bulb is on the rear and to access it you must remove the entire control panel. That requires removing the vertical pieces along side of the radio (by simply getting your fingers behind and pulling), removing the radio trim (again just pulling), and then pulling the AC control panel off.
Tags
climate bulb replace
The electronic climate control displays mrbond In Car Entertainment + Electronics (audio / video / alarm) 43 04-18-2021 03:34 AM
Digital Gauges, Auto Climate control, Manu-matic shifter computerlove87 Cosmetic Modifications (Exterior/Interior) 21 12-02-2012 11:55 PM
Yaris 09 climate control lights alt_k1ll3r DIY / Maintenance / Service 2 11-11-2008 10:19 PM
Bulbs For Behind The 3 Climate Control Knobs razzorjet2 DIY / Maintenance / Service 2 04-06-2007 10:41 AM
