Old 04-07-2013, 05:39 AM   #1
Yaristeve
Drives: 3-door hatch
How/why does the 16X7, 40mm offset wheels, 185/50 combination rub anywhere at all? It is slightly shorter than the stock setup but the same width and offset...
I am concerned/curious because I am planning on getting 16X7, 40mm offset wheels with 195/50-16...
TIA
Old 04-07-2013, 02:13 PM   #2
TIA
OP and you normally wouldn't have problems (I had the same spec wheels, and 205/45/16 tires). However, OP did say his fender liner was broken and is sagging a bit.
Old 04-08-2013, 09:29 AM   #3
dmytro_syroyizhka
Drives: Toyota Yaris Black 2007
Yes my fender liner is sagging and my car is dropped quite a bit on lowered springs not coils. I took off the fender liner for now while its nice out and i have no trouble. Drove with two other buddies in the car and it was fine. I just recommend low profile tires like 185/40/16 but thats not possible around here because ohio roads blow
dmytro_syroyizhka is offline   Reply With Quote
LB Front fender liners ozmdd Willing to Buy by private party 4 02-01-2010 08:26 PM
