P0420 9 times out of ten is a bad catalytic converter. Which can be cause by a bad o2 or worn out plug as some of the common causes. I would take your car to a muffler shop and see what they can do to help you. You can probably find a aftermarket one for cheap since you dont need a California approved cat. Typically about 200 installed.
#2 | |
| DIY- rattle from lower windshield fix. | PetersRedYaris | DIY / Maintenance / Service | 3 | 08-21-2011 12:29 AM |
| Yaris Central Locking Problem | pbasuita | UK | 0 | 07-10-2010 03:46 AM |
| Gas pedal problem? | Befuddled | Performance Modifications | 28 | 01-27-2010 09:55 AM |
| Problem with opening my trunk | vargas | DIY / Maintenance / Service | 3 | 08-31-2007 03:29 PM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
