Old 07-23-2007, 01:22 PM   #1
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
so i read every lil facet about pulleys on nst's website and these lite pulleys are the same diameter as the oem pulleys so they dont change timing in any way, right? its because they dont weigh as much as the oem pulley that makes better use of the engines output. am i right?
Old 07-23-2007, 01:28 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
size size just lighter, so less rotational mass = better MPG and more HP transfered to the ground because less is being waisted trying to sping the hevier pulley
Old 07-23-2007, 07:44 PM   #3
NonStopTuning
Crank Pulleys and accessory pulleys have nothing to do with cam timing, whether they be underdrive, overdrive, or simply light weight variants. The concept is in regards to the rotating assembly and the transfer of horsepower between the crank shaft and the accessories which translate this horsepower into the services they provide. ie the alternator, a/c, etc.
Adjustable Cam Gears, also called cam pulleys by some, are directly attached to the camshafts and allow the individual tuner to change the timing of the camshafts, thereby changing the powerband of the engine. Adjustable cam gears are usually used in conjunction with aggressive aftermarket camshafts and wouldn't do much for mildly modified engines.
Feel free to look for me on AOL Instant Messenger at the screen name NSTonAIM should you wish to chat about any of our products in further detail. I would be happy to be at your service.
NST FTW FE&EMFs
MIKE @ NST
www.NonStopTuning.com
Old 07-26-2007, 11:05 AM   #4
Dezod
The Scion Guru
Dezod's Avatar
Drives: Scions
NST rocks!
We are a proud NST distributor and have MORE stock coming in!
Dezod Motorsports Inc-'We ARE performance."
P: 716-681-6666
E: sales@dezod.com
W: www.dezod.com
Your leading source for all of your performance needs! From turbos and components, to brakes and suspension, Dezod has you covered.
Dezod is offline   Reply With Quote
Old 07-26-2007, 01:38 PM   #5
I got my pulley on today, and there is a nice bump in low-to-midrange. Can't feel much when winding it up, but that's fine.
My only tiny gripe about this pulley is the timing notch is too small, barely there really. Won't matter much until smog time, though, since the car tunes itself. Overall, VERY nice product.
Old 07-26-2007, 01:38 PM   #6
are the other two pulleys available yet?
Old 07-26-2007, 01:39 PM   #7
ChinoCharles
Drives: LB
They are being researched as we speak. Look for the GB coming soon!
Old 07-27-2007, 03:27 PM   #8
RUBBERDIPSTICK
Drives: Toyota Yaris Base Sedan
I'm onboard with the other pullys...lets do this
RUBBERDIPSTICK is offline   Reply With Quote
Old 07-27-2007, 04:22 PM   #9
Jerkratt
Jerkratt's Avatar
im on ti waiting for the GB lol
"It hurts more when its wet"
Old 07-27-2007, 08:18 PM   #10
NonStopTuning
Start looking under your couch cushions, in your ashtrays, and old jean pockets boys and girls. New pulleys are a comin!
MIKE @ NST
Old 07-27-2007, 09:05 PM   #11
Shijima
Drives: 07 HB
I found $135.00 in Change in my room today, its going to be the start of my pulley fund.
Shijima is offline   Reply With Quote
Old 07-28-2007, 12:36 AM   #12
I've been stealing from my son every time I do the laundry.... that's my pulley money.
Old 07-28-2007, 03:51 AM   #13
jdium
Mr Attitude
jdium's Avatar
Drives: Blazing Blue 5 Spd
I understand that it might not be a good thing for vendors or NST to post a dyno chart of before/after, unless the results are premium, but I'd love to see what the real world results of this are...hopefully somebody has access to a dyno for after the GB...gotta see if this is just doing a mod to do a mod...
It's scary to think that half the people surrounding you are below average...
jdium is offline   Reply With Quote
Old 07-28-2007, 03:57 AM   #14
ChinoCharles
Drives: LB
http://yarisworld.com/forums/showthread.php?t=3239
Scroll down on the first page and you'll see dyno sheets from an Acura TSX and Lotus Elise. If NST can make power on a Lotus, you think they can handle your Yaris?
Old 07-28-2007, 04:27 AM   #15
jdium
Mr Attitude
jdium's Avatar
That's what I want to see 1st. The Lotus graph looks terrible, what happened at 6k? As for handling my Yaris, I'm sure it's worth a little hp, but I wanna see the curve. I'm also sure that Toyota wouldn't leave more than a couple hp on the table in a market that is so closely matched.
Old 07-28-2007, 03:01 PM   #16
NonStopTuning
Why do the Lotus graphs look terrible? The Lotus Elise and Exige are basically track ready cars out of the box. The Elise has some of the lightest and most efficient OEM pulleys I have ever worked with, and NST pulleys still provided positive gains.
What happens around 6,000 RPM is the Toyota Variable Valve Timing (VVTi / VVTLi) that kicks in. The engine makes a lot more power from 6,000 to redline, as evident in the graphs there.
The same thing can be seen in the dyno chart above posted about the Civic Si and the Acura TSX. Vtec kicks in around 6,000 RPM and power increases significantly.
As you can see, NST pulleys continue to free up power even beyond this point.
MIKE @ NST
Old 07-28-2007, 12:19 PM   #17
whooppee777
is he serious?
Old 07-28-2007, 12:33 PM   #18
Shijima
Drives: 07 HB
Why wouldent he be, obviously his son doesnt want it!
