Old 10-26-2008, 02:27 PM   #1
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
i let you know by today i have to install it on my gfs car which is an automatic
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-26-2008, 02:33 PM   #2
ZING
ZING's Avatar
Drives: Yaris '09,GTi '09, BMW 3.30ci
Excellent, thanks
ZING is offline   Reply With Quote
Old 10-28-2008, 09:58 AM   #3
lamdog
Drives: Yaris YRX
received a underdrive pulley from Gram today..
tried to fit it, but no luck... the bolt is freaking hard.
i have also tried an electric drill to take it off, the bolt did not move at all.
sighs... gonna take the pulley to my mechanic this weekend, i cannot wait....
lamdog is offline   Reply With Quote
Old 10-28-2008, 11:05 PM   #4
battleversiontc
yeah i had to use an impact gun to remove the bolt for the crank
and a 10mm wrench for the water pump pulley along with a thick srew driver through the holes to loosen the water pump pulley bolts and i just impacted the alt pulley it was all good after that
Old 10-31-2008, 08:32 AM   #5
lamdog
Drives: Yaris YRX
got my underdrive pulley on today...
took it to my mechanic, it was just a piece of cake with air tool....
i could notice that the throttle is much lighter right after the pulley was on...
no unusual vibration after.
Old 11-05-2008, 12:28 AM   #6
NonStopTuning
Thank you sir
MIKE @ NST
www.NonStopTuning.com
Old 11-06-2008, 01:11 AM   #7
battleversiontc
im waiting to find out the differences with the mpg on these i hope to see alot of improvement on this since now i dont really push the gas down as much now
Old 11-20-2008, 04:03 PM   #8
NonStopTuning
Originally Posted by richardholdener View Post
Here are the official results of an honest back-to-back dyno test of the NST pulleys (crank, alt & WP). Car was run on the dyno with stock pulleys and then we swapped out the stock pulleys for the NST (I believe 10% under driven) though sizing on WP and Alt looked the same. Pulleys were definitely worth some power as indicated by grpah. Note also the power numbers (123 wheel hp) is a new NA record-posted elsewhere with description of mods.
Thanks again Richard, your hard work and dedication is much appreciated
Old 11-20-2008, 07:35 PM   #9
*MAD DOG*
*MAD DOG*'s Avatar
Is that dyno a stock car vs the same stock car with stock pulleys removed and NST pulleys (including 10% underdrive)? Were there no other engine/exhaust mods?
Old 11-20-2008, 07:54 PM   #10
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
There are a lot of other modifications on that Dyno chart. Intake Manifold, custom long tube header, and others.
However, is important to mention that NON of those other mods modify in no way the output / gains provided by the pulleys.
That means that the 3whp gain all across the power band will be the same on an unmodified car.
And yes, that is a complete pulley set including the 10% underdrive crank pulley.
Old 11-20-2008, 07:41 PM   #11
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
One with pulleys and one without thats about 3hp!
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 11-20-2008, 07:57 PM   #12
*MAD DOG*
*MAD DOG*'s Avatar
Thanks for clearing that up.
Old 11-21-2008, 02:18 PM   #13
NonStopTuning
And now some breaking news from NNN (NST News Network)
75% lighter than OEM.
Slight underdriving of accessories EXCEPT alternator.
Hard anodized aluminum.
More info...
http://nonstoptuning.blogspot.com/20...-yaris-ts.html
MIKE @ NST
Old 11-21-2008, 02:47 PM   #14
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
very nice! btw Mike i had a problem installing my short shifter. it did not slide on very easy with out me having to grind out the bottom a little. just fyi...but other than that..TOP NOTCH!!! love the new shifts
mikenacarato is offline   Reply With Quote
Old 11-21-2008, 03:02 PM   #15
Thej3sta2
Thej3sta2's Avatar
Drives: Soon to be LFA
gangsta leen
Thej3sta2 is offline   Reply With Quote
Old 11-21-2008, 06:11 PM   #16
NonStopTuning
Originally Posted by Thej3sta2 View Post
gangsta leen
NST pulleys are GANGSTA
MIKE @ NST
Old 11-21-2008, 05:16 PM   #17
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Can't see PICS!
R-CaT
Project Yar 2ZR
Old 11-21-2008, 06:12 PM   #18
NonStopTuning
Originally Posted by RagnaCaT View Post
Can't see PICS!
Really?! Anyone else having a problem with the pics?
MIKE @ NST
