Old 11-14-2009, 06:21 PM   #1
SLIK4
Michael
SLIK4's Avatar
Drives: 07 Silver Yaris Sedan
i do not have any NST products but have read alot about them and respect them a great deal for making unbelievable products. i am really wanting the crank pulley a great and will hopefully get one in the future most likely from micro image . just wanted to say thanks again to NST for being such a great source of info. i have learned a alot from reading on this thread.v
NST FTW!!!
SLIK4 is offline   Reply With Quote
Old 12-09-2009, 09:50 PM   #2
NonStopTuning
NST FTW!!!
Thank you SLIK! And if you like NST this much now, wait till you have some of our products on your car!!!
MIKE @ NST
www.NonStopTuning.com
Old 12-20-2009, 09:28 PM   #3
jonismyname
Drives: 08 liftback 5spd
time to say my part. installed my 10% UD pulley in about 15-20 minutes in a garage with air tools. if you're a little person you'll prob have troubles getting the alternator loose... and i found removing just the two upper screws on the plastic fender thing was enough to get to the pulley...
immediate boost in throttle response, and acceleration. car feels lighter and more lively. i've done a number of mod's on the cheap to my car, including modified intake and axle back, and nothing has done more for my performance than my pulley i installed last night, regardless of cost. very happy with product and will recommend at every opportunity.
jonismyname is offline   Reply With Quote
Old 12-20-2009, 11:22 PM   #4
NonStopTuning
Thank you Jon. Glad to read your review and very happy that you are satisfied with your purchase.
Good luck and have fun with all your future projects!
MIKE @ NST
Old 12-21-2009, 12:06 AM   #5
yaris2010RS
yaris2010RS's Avatar
is this tested on the 2010 1.5l yaris yet?
Old 12-21-2009, 07:05 PM   #6
NonStopTuning
NST pulleys and kits are compatible with the 2010 Yaris
MIKE @ NST
Old 12-26-2009, 10:34 PM   #7
danielmid
Installed the NST underdrive pulley today, took about 30 minutes. Awesome.
danielmid is offline   Reply With Quote
Old 01-03-2010, 09:47 PM   #8
NonStopTuning
Glad you like your new pulley!!!
MIKE @ NST
Old 02-07-2010, 01:35 AM   #9
NonStopTuning
Anyone else have any real world reviews to share? Those of you who have owned NST pulleys for several thousand miles... it would be much appreciated if you would chime in with your updates.
Thank you.
MIKE @ NST
Old 02-08-2010, 01:29 AM   #10
*MAD DOG*
*MAD DOG*'s Avatar
Just had the NST CR Lite Crank pulley installed at a mechanic. They quoted me $90 labour an hour. They did the job in just under 30 minutes and charged me $45 woot.
First thing I noticed was when I put my foot on the gas pedal the car responded quicker and appeared to take off from a stop start faster and easier.
Then I drove around for a while with a big grin on my face and was very happy when a set of lights turned red (another chance for a take off test). I'm very happy with the NST product and would recommend it to anyone and everyone with a Yaris.
My wife has a 1.3 litre Yaris, I think the biggest gain would be on her engine. Maybe I’ll talk her into one of these and then get the 10% underdrive for myself.
NST FTW!
Old 02-08-2010, 01:35 AM   #11
Astroman
Modded Moderator
Astroman's Avatar
The bodyshop at the dealership noticed my NST pulleys and asked me all sorts of questions about them and were quite impressed. I think my Yaris is the only one they've seen that has just more than aftermarket wheels on it. Over 50k miles so far on my pulleys and I couldn't be happier.
Old 02-08-2010, 01:37 PM   #12
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
11K miles on my NST Underdrive pulley. 15 autocross events, 3 time trials. Zero problems, dyno-proven HP gains (see dyno thread), completely satisfied with the quality, aesthetics and performance of the product.
Old 02-08-2010, 02:00 PM   #13
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
I'm not sure if this is normal, but I was checking the pulleys I installed, well the waterpump nst pulley is starting to get engraved into. Meaning the belt is digging into the pulley so that theres an engravment from the belt in it is this normal if anyone knows what i am talking about?
Aothachos is offline   Reply With Quote
Old 02-08-2010, 02:13 PM   #14
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Yes, that is normal, everything will wear off eventually, even the strongest materials, just give it enough time and friction. The OEM water pulley is painted black, but when I took mine off it had a shiny strip where the belt makes contact.
Think of it almost as an infinite polishing machine
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 02-08-2010, 02:15 PM   #15
Aothachos
so eventually overtime I will have to replace the pulley? Is there a set certain amount of miles that NST recommends to replace it if so? It has been about 25-30 thousand miles since I installed these. I think it is also why my belt is squeaking everytime i start up because it is loose due to friction engraving its place in it lol
Old 02-08-2010, 02:26 PM   #16
fmicle
fmicle's Avatar
Hmm, honestly, I don't know, but then aluminum is lighter and softer than steel, so I wouldn't be surprised at all if it wears off much quicker. Can you really see/feel a groove where the belt sits? If it's just polished shiny I wouldn't worry too much. It would be interested to compare with an older OEM water pulley, see if you get the same wear after a while.
My belt is squeaking too, 1 in 10 starts I'd say, because I couldn't get it as tight as it should be. But I'm working on adapting the Scion xD belt tensioner to the Yaris and if I can make it work, I'll post the DIY
Old 02-08-2010, 02:42 PM   #17
Aothachos
no the groove is pretty deep i say about 1-2mm, u can feel the edges perfectly where the belt sits on the pulley
Old 02-09-2010, 06:30 PM   #18
jouna
jouna's Avatar
Drives: jdm yaris sedan
is there a big difference installing the power pulley set versus the underdrive pulley alone? i mean is it worth it?
vvti bregao!
jouna is offline   Reply With Quote
