#1 | ||
I know that, buddy. Which is why there's no need to bring up the dampener subject, is there?
![]() Quote:
Having one (allegedly) faulty pulley (out of hundreds if not thousands of pulleys made by NST) potentially damage the reputation of a company that is backed by the tuning/performance scene in general but also these forums in particular doesn't seem like fair treatment to me, especially since we don't have enough facts about this particular case to reach any kind of conclusion either way. Also, having someone post a potentially damaging post without consulting with the fabricator first doesn't seem fair to me either. But I guess that's just me.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
![]() ![]() Drives: 1NZ-FE Join Date: Oct 2008
If u can still see my past posts, i did post on this thread before asking about this pulley. I have post some doubts on the wear and even post a pic on it long ago.I have great confidence in the product. But it fail me after 50000km++ so its the end of NST road for me. This is a fact.
![]() ![]() ![]() Drives: 07 liftback Join Date: Nov 2008
I think he's being perfectly fair about his statements over the pulley breaking on him. If I bought something somewhere, and it broke on me, I'd be damned sure to tell EVERYONE that I knew who might buy something there as well. That being said, I still fully endorse NST pulleys, as I've had mine for almost 2 years now, and I still love them. Just nobody can make something 100% perfect, there will be some problems somewhere, sometime.
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
60+ thousand miles on my full set and no problems. Perhaps the bolts were improperly torqued? Not bad seeing 1 problem out of thousands of users.
![]() ![]() Drives: Yaris Sol 1.3 dual VVTi 101hp Join Date: Apr 2009
and for my "poor" 1NR-FE also known as 1.33 (101hp)... which pulley should I look for ??
Yaris Sol 1.33 dual VVTi model 09 - 5dr 1. full ZX1 additive treatment: oil + cooler + fuel 2. NB treatment: motor oil 3. K&N panel air filter (part num. 33-2211) 4. Fuchs Silkolene Pro SRG 75 gear oil (the best!) 5. UltraRacing 19mm rear sway bar |
![]() ![]() ![]() Drives: peArL yAvItZ!! Join Date: Jul 2009
Hi to all, can anyone Thai made Yaris mount on the water pump & alternator pulley without any problem. All Thai Yaris with this mod, PLEASE advise & confirm...
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres |
![]() ![]() ![]() ![]() ![]() Drives: NST CARS: S13 AE86 ANT10 AW11 Join Date: Dec 2006
![]() Drives: Yaris Sedan Base 1.5 A/T Join Date: Aug 2010
About NST (NonStopTuning) Pulleys, does anybody know if they work in a yaris sedan 1.5 a/t? I also ordered but not intalled OBX headers, K&N Typhon intake, Magnaflow muffler and the sprintbooster (electronic throtle accelerator).
I'll apreciate all your comments. Thanks |
Does it fit in yaris sedan 2007 1.5 a/t??
Where can I find one for a 1krfe?
In SA
--------------------------------------------------- “Do or do not... there is no try.”
![]() Drives: 2008 liftback Join Date: Dec 2010
For those who have the full lite pulley set, would anyone care to give their impressions? I'm interested in these.
The biggest bang comes from the crank pulley. The others in the set are mostly cosmetic.
#14 |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
^ hey aurora, i have a cottage there (ninth line area)
as for the pulley set its really amazing. there is such a huge difference with them on. only issue is getting them on :p crank pully wasnt too bad to put on but holding it while tightning the blot was a challange. i also have lite water pump pully which took some time too get on but was very happy with the results none the less.
#15 |
^ why are the others in the set cosmetic? Is there anyone that started with just a crank pulley and added the other two pulleys later? I'm definitely going to get at least the crank pulley, but I'm on the fence on the other two.
#16 |
Yes....however it was when they introduced the crank first. Then the others came out. I believe cheaper prices were in back then also.
#17 |
i put just my crank on first and tested it out and i noticed a massive difference. put the water pump pully on and noticed nothing. the water pump pully i got was also grey so its not cosmetic at all..... i recommend only getting the crank and if i could do it all over again thats all i would get. the stock water pump pully is maybe only 1lbs difference then the lite one but the crank is almost a 20 lbs difference
#18 |
Only Happy When it Rains
hey, when you are talking about things that rotate every ounce counts. It might not be a ton, but the lighter those pulleys are, the less effort it takes to spin them, meaning more power for what really counts.
Colin Chapman disciple |
