Old 05-03-2007, 07:15 PM   #1
NonStopTuning
Originally Posted by Dezod View Post
Bump for Mike and NST~
We have NST pulleys in stock in blue and gray!
http://www.dezod.com/pd_nst_crank-li...y-yaris_06.cfm
Dezod Rocks
MIKE @ NST
www.NonStopTuning.com
Old 05-03-2007, 07:19 PM   #2
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Drives: 5-Speed Liftback
Send a message via AIM to Ran Kizama Send a message via MSN to Ran Kizama
Doesn't NST have other pulleys in the works as well? If so, I think I'll wait and get them all at once.
Ran Kizama is offline   Reply With Quote
Old 05-04-2007, 01:32 PM   #3
Terrorize
Toyota Newb!!
Drives: Yaris S Sedan w/ Aero Package!
I think they mentioned something about it being in development...or something...or was that ZPI?
Anyways...i just got my NST installed...and its great so far! I noticed the weight diff of the 2 pulleys when comparing them! The stock and NST...
Thanks Dezod and NST!!
Terrorize is offline   Reply With Quote
Old 05-04-2007, 01:54 PM   #4
Dezod
The Scion Guru
Dezod's Avatar
Drives: Scions
Welcome. Glad to see all arrived well.
Dezod Motorsports Inc-'We ARE performance."
P: 716-681-6666
E: sales@dezod.com
W: www.dezod.com
Your leading source for all of your performance needs! From turbos and components, to brakes and suspension, Dezod has you covered.
Dezod is offline   Reply With Quote
Old 05-04-2007, 02:55 PM   #5
YarisGuy
Drives: 2006 Yaris
According to Mike of NST, they will have more products for us in the future if we support them and buy their current products.
NST FTW! Everyone else who copies them FTL!
It's a red yaris
YarisGuy is offline   Reply With Quote
Old 05-04-2007, 01:48 PM   #6
ChinoCharles
Drives: LB
The plan is for 2 more pulleys to come this summer.
Old 05-04-2007, 01:49 PM   #7
Astroman
Modded Moderator
Astroman's Avatar
And I am SO buying them!
Old 05-04-2007, 05:24 PM   #8
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
I think I'll wait and do them all at once then.
Old 05-04-2007, 07:42 PM   #9
Astroman
Modded Moderator
Astroman's Avatar
Yeah, you could do that... But buying the CR pulley now helps fund R&D which will get the rest of the pulleys out sooner. You would also save some gas if you bought one now, my MPG improved 1-3. It would probably be more convenient though to get it all done at once. Regardless if you wait for the whole set or get it piece by piece, your going to really enjoy the results
Old 05-05-2007, 04:10 AM   #10
YarisGuy
Drives: 2006 Yaris
I have the NST CR-Lite and could not be more happy with it. Better response and better MPG.
NST FTW! All other copy cats FTL!
It's a red yaris
Old 05-07-2007, 10:06 AM   #11
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
I've heard mention of a harmonic balancer when it comes to pulleys. Anyone care to enlighten me as to if the pulley needs one or not?
Old 05-17-2007, 05:35 PM   #12
TheCutsman
TheCutsman's Avatar
Drives: 07 Meteorite 3 Dr Liftback
Yes I would like to be enlightened also
______________
07 Meteorite Metallic Liftback
TRD Lowering Springs
Tanabe Strut Tower Bar
Fujita F5 CAI
Autometer Tach
NST Quickshifter
TheCutsman is offline   Reply With Quote
Old 05-07-2007, 10:38 AM   #13
well, after now having the thing in 24 hours, I can feel a few differences from before... For one, the engine does feel more responsive, looser, easier to rev up. How can I tell? My ger-changing timing's all off and jerky now, the engine gets up to speed faster, so I'm over-revving by the time I engage the clutch the "old" way. Should take a couple of days to get adjusted.
Although, at low speeds, the engine is a little more shaky, the advantage of a havier pulley and/or flywheel is more inertia, allowing the engine to spin more smoothly... But, that's also just a matter of getting used to it.
Over all,
Old 05-07-2007, 12:18 PM   #14
AlphaFox
AlphaFox's Avatar
Drives: 07' Yaris Liftback - silver
I like mine, but yes it does idle rougher sometimes when the rpms drop under 600. overall im happy with it, definatley more power throught the entire rpm range. funny thing is I really notice it when im engine breaking, it definately helps stop faster!
AlphaFox is offline   Reply With Quote
Old 05-08-2007, 04:05 AM   #15
Terrorize
Toyota Newb!!
Yeah...i feel the same benefits in mine...
However my mechanic was telling me what i might experience after changing the pulley...and he did mention that there might be more vibration now...and there is a bit like you guys mentioned..but nothing i can't get used to..
he said its due to a lighter pulley...plus the OEM pulley had some kinda or rubber gasket on it to help dampen the vibration?
Old 05-08-2007, 01:59 PM   #16
Astroman
Modded Moderator
Astroman's Avatar
No such rubber on the OEM pulley. I saved my old one and inspected. All metal & paint.
Old 05-12-2007, 11:58 PM   #17
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Mine has a rubber ring between the hub and the grooved pulley ring. Most OEM pulleys do. Check yours again and you will see it, and feel it.
Old 05-13-2007, 02:01 AM   #18
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Do you think it might be possible to swap that ring with the new pulley? Would the NST still fit? Or maybe NST would like to add a rubber ring for an extra buck or two?
