![]() ![]() Drives: 06 yaris AT Join Date: May 2007
Mike, your link to the DIY installation is dead? Also when will you be releasing the pulley kit (WP and Alternator pulleys) ? I'm interested.
Mike, I saw another pulley kit with the wp and alternator pulleys. When will these be available?
![]() ![]() ![]() Drives: 2006 Yaris Join Date: Dec 2006
A lot of these questions where brought up in the original GB thread when we all signed up for these pulleys. The vibration damper in the stock pulley is a think rubber band that hardly does much. After talking with Mike of NST on his screen name (NSTonAIM) it sounds like NST is capable of building pulleys with these rubber pieces in them, but the costs would be 3 times what they are now. The rubber is very over rated and NST has removed it in 99% of the cars they build pulleys for. The rubber has not proven to be a necessary component of the pulley in all their testing and the testimonial of thousands of aftermarket pulley users for the past 15 years or so.
It's a red yaris
#4 | |
#5 | |
Well, I would guess a pulley is being made in a two step process (CNC mill, then anodize), but if you want a rubber insert, it would be made in a lot more steps, as two pieces of aluminium need to be made, then a piece of rubber needs to be made, and sandwiched between the aluminium. All these extra steps would need more time, and a lot more labor, and as a result, a lot more money
#6 | |
Great. Now I've got the munchies.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#7 | |
![]() ![]() ![]() ![]() ![]() Drives: NST CARS: S13 AE86 ANT10 AW11 Join Date: Dec 2006
Furthermore on the topic of the rubber damper, engine vibrations, or possible threats resulting from elimination of this rubber piece... On a relatively understressed near stock motor with bolt ons or low amounts of boost like what most of the people on this forum probably run, a solid pulley will not have any life threatening consiquences. The factory pulley with a 2mm (less than a 1/8th inch) damper is primarily there for wide band NVH (noise vibration harshness) supression from the engine and driveline. Removing the damper and replacing it with a solid pulley will lead to minor addtional NVH but will not harm the engine. In fact, most people claim their engines seem to run smoother with NST pulleys. The engineering reasons are that most modern engines have a short, strong crank with, a relatively high natural frequency. The dangerous second harmonic that can cause damage occurs at an rpm that this sort of engine will never see, in the area above 10,000 rpm. Even the stock damper is not tuned for attinuation at this sort of rpm so the argument is somewhat of a moot point. Now small engines that are pushing the limit with lots of revs, wimpy cranks, super long strokes, lots of boost and dwelling in the upper rpm ranges for long periods of time can benefit from a damper designed to deal with this sort of operation but our engine is not like this, and probably very few people with this motor on this forum push the envelope that hard. How many 1.5Liter, 400HP, 11,000RPM Yaris motors do we have on these forums? As far as I can tell, our engine has a strong and stiff bottom end that is well built for our intended use. It has an internaly balanced crankshaft which is less like to break due to torsional vibration. There are a lot of Nissan guys who use underdrive crank pulleys in road racing series like NASA or SCCA. Road racing is much more punishing on an engine than other motorsports. The engine is subjected to run times lasting 23 to 45 minutes with the engine always in the upper ranges of its rpm limit. One race weekend is the equivlent of hundreds of 1/4 mile passes. NST sponsors the first ever wheel to wheel Scion tC NASA Road Race car. This car has been using underdrive pulleys from NST with great results since day one. NST also sponsors two drift cars participating in the professional US drift series, Fromula Drift. Both of these cars have been using NST pulleys with no issues of any kind for the past few seasons. We could go on and on... Is a solid crank pulley harmless to all engines? No it is not. Small, super high reving engines, when modified way past the simple bolt on stages may have problems. These engines reach critcal harmonics, past the 10,000 rpm range, an rpm often reached by certain race engines. A mildly modded inline six will most likely be fine but one subjected to high rpm for long periods of time (90% of its life) with lots of boost will probably suffer. In this case , the stock balancer/damper is probably not adequate either. Some of the older american V8 engines are externaly balanced and it is critical not to use a solid hub pulley not designed for these applications, or damage to the engine could result. Our engines and most around here do not fall into the above catagories. Rest assured that your engines will not blow up and die or have a reduced life in street and even racing use with these parts. I would bet that every "expert" that tells you otherwise has little personal, practical, real world experience with the subject. . Last edited by NonStopTuning; 05-17-2007 at 07:52 PM. Reason: spelling errors! |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
Installed mine last weekend, got a little over 200 miles on it now. Like others have said, faster, smoother acceleration, a good bit more bite in the bottom of 2nd gear, also much smaller "hole" in the top of 2nd/3rd. GREAT $100 mod--looking forward to NST releasing the rest of the set.
About the torque thing though--earlier post said less rotating mass means less torque, but it feels like more... How does less force to get the thing spinning affect torque? Or am I just confused about how torque works? Only explanations I can find online have too many mathematical equations... ![]() ![]()
#9 | |
And regarding your torque question, take a look at some of our dyno testing we have done on different applications. You can see that the entire power band has been shifted up at every point in the RPM band. NST kits provide more HP and more TQ at every point you look at. Less rotating mass on the engine itself will always lead to such results... ACURA TSX INFINITI G35 LOTUS ELISE (has some of the lightest OEM pulleys I have ever seen!) Don't forget, NST is the only company building pulleys that is actively involved in testing products in RACE CARS. We have several NST sponsored cars in pro road racing and drift series accross the USA. Our products are built and tested on race cars as well as street cars. We do not build products unless they provide real world gains that we can clearly observe in our testing. Last edited by NonStopTuning; 06-07-2007 at 04:17 PM. |
The Scion Guru
Drives: Scions Join Date: Feb 2007
Go Don!!! That is the road race tC we are involved in as well. :)
Dezod Motorsports Inc-'We ARE performance." P: 716-681-6666 E: sales@dezod.com W: www.dezod.com Your leading source for all of your performance needs! From turbos and components, to brakes and suspension, Dezod has you covered. |
Again with those ladies!!! I thought we told you not to tease us anymore.
#13 | |
#14 |
They can crank my pulley any time they want....
#15 |
![]() ![]() Drives: 07 HB Join Date: Apr 2007
Great advertising, I'm hooked now. Will definitly be getting the pulleys do to the great reviews once I get my yaris.
When do you plan to release the rest of the pulleys? |
#16 | |
We have a few other goodies in the works for the Yaris community, these should be out within the next couple months. The more you guys support us, the more we can do to support your community. Stay tuned... |
#17 | |
![]() You people defending you-know-who all over these forums spit in the face of two of our members who received shit products and shit service. I for one have more respect for our membership than to lend my support to an undeserving company. They bought their way onto Scionlife and I'll be damned if they do the same here! If they want my respect, they can earn it. NST already has. Have yet to see one person buy an NST product and not be satisfied. |
#18 |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
