Old 04-09-2013, 05:43 PM   #6
Not sure exactly where the fuel test port is on the yaris. If you have the engine cover off already on the fuel rail there should be a little plastic cap if you unscrew it you should see the valve. Take a pen or small screw driver and depress it with the key on and see if fuel squirts out. If not have someone trying to crank the car while you press on it and see if fuel comes out.
The Yaris does not have fuel test port. Toyota techs have a SST kit that contains a T fitting that connects in between where the fuel rail meets the fuel line.
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Yaris starts then it wont start. wush11 General Yaris / Vitz Discussion 18 01-05-2011 11:53 AM
Let's start a Yaris Club, each member has a specific number decal Yawesh General Yaris / Vitz Discussion 48 04-10-2009 10:49 PM
