Old 04-10-2013, 11:22 AM   #10
esse10
Drives: 2009 yaris 2 door
throttle valve
You should check anything that would effect your emissions effeciancy and with that many miles I would check & clean the throttle body valve& MAF sensor. If it has never been cleaned before rest asure it's got lot's of gunk on it. Then reset your cpu by disconnecting the battery for a while, then reconnect because the MAF sensor will try to re-adjust air flow again and the idle might be off after the first few cold starts, then it'll smooth out. Good luck man
esse10 is offline   Reply With Quote
DIY- rattle from lower windshield fix. PetersRedYaris DIY / Maintenance / Service 3 08-21-2011 01:29 AM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 04:46 AM
Gas pedal problem? Befuddled Performance Modifications 28 01-27-2010 10:55 AM
Problem with opening my trunk vargas DIY / Maintenance / Service 3 08-31-2007 04:29 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 10:12 PM
